Ferry missing - pls help
Hi, tried to make the following route
Lübeck → Poland → Tallinn → Helsinki → Turku → Stockholm → Copenhagen → Lübeck
Ferry:
OK Tallinn to Helsinki
Not OK Turku to Stockholm
OK Rødby to Puttgarten
But Kurviger does not make the Ferry crossing from Turku → Stockholm … The other two ferry crossings were created
Pls help
I would prefer Kurviger to create route (alternatives would even be better), without having to cut the route in pieces like the work around here: … 1) Lübeck → Turku 2) Stockholm → Lübeck
Pretty satisfied with Kurviger though :slight_smile:
Can you share the link to the route so we can have a look at it? Sometimes it helps if you put a shaping point on the ferry route (yes - in the water) that you want to use.
Looks like there is no direct ferry in OSM:
However, with toothless’ proposal (SP in the water) you can create the ferry route, but due to many different ferries I think the algorithm gets a bit puzzled - so with a little manual help it does not look too bad:
However, will take it to the team for looking more in detail in this :slight_smile:
Just as addition. I found in OSM (at least) three lines driving between Stockholm/Turku (or at the coast).
Silja Line: Stockholm => Långnäs => Turku (9644416)
Silja Line: Turku => Långnäs => Stockholm (2894450)
Finnlines: Naantali => Långnäs => Kapellskär (9645537)
Finnlines: Kapellskär => Långnäs => Naantali (9645538)
Viking Line: Stockholm => Långnäs => Turku (5310494)
Viking Line: Turku => Långnäs => Stockholm (5310496)
Good idea. Perhaps something like the search for POI, also for ways/relation. Questions for ferries are quite often.
I had a look at the ferry and was not able to see what the issue was. The connections stops somewhere on the water. I am not sure if maybe something in OSM changed. I will keep an eye on this, but right now, I have no good answer :thinking:
The simplest solution is to just make a beeline between the two points connected by the ferry.
