Fixed Popup Shows Route Details
Hi Emux,
I use normally the pro App on my Tablet to plan the root and download the Tracks to my Garmin Navi.
There is small pop up on the bottom during planning it shows the distance and the time. I wish this pop up is always visible and not only a few seconds.
Reason: during planning i need always these info. To See fits the Route in time and distance.
Cheers Jens
Hi Jens,
Thanks for the interesting proposal!
We need to think an elegant way to provide that. :slightly_smiling_face:
Also can check documentation where are described all current ways to see route details:
  • Tap on the route, a popup will show you the time and distance
  • You can go to the Menu , Routing , Route
  • You can long press on the route
Thanks for the hint. (Tap on the Route)
Thats it :slight_smile:
