Hello I found how to skip waypoint but not to go to a specific waypoint. I want to avoid to skip multi way points to go to the desire one, I’m pretty sure there is an option to achieve that (while navigating)
Thank you in advance
Hi @Joel_05,
I might not quite understand what you mean yet, but with Kurviger you can select a specific waypoint while navigating, to navigate there next (in which case, all waypoints between you and the selected waypoint will, of course, be skipped). You can find a video of this feature here. ![]()
I understand about skip way point but if for any reason you want to go to last point, and that you have 50 way points, it’s not logical to skip one at a time each way point, very long.
The best would be to have option to go directly to way point 50
You can also simply tap on the waypoint on the map to skip directly to that point. For bigger planning actions we recommend to go back into planning view.
