When I plan a route and then save it in GPX, there are errors. I get rid of these by setting lots of intermediate destinations.
Hello @Hansruedi_Hassig and welcome to the Forum
Could you provide some more information about the problem:
- what kind of errors have you encountered?
- which export settings are you using to create the GPX file?
- which navigation device are you using to import GPX?
- have you used Kurviger GPX-Export without these errors prior to the recent Export updates?
- post an example of an erroneus GPX if possible
- post “Debug Info” from the bottom of the Kurviger settings menu
Also, this guide might help you.
Hello Forum
My problem is solved. I discovered that the program that opens GPX files is faulty (GPXSee). Everything works fine with another program.
