Hallo Randyak, hast du es mittlerweile hinbekommen mit der GPX vom old.export ? Fahre die Guerrilla mit dem Dash, wenn man export klickt und nur Track auswählt, klappt es mit der RE App.. Was mich nur stört ist, wenn man einen Wegpunkt erreicht, kann ich manchmal nicht erkennen wo die Route weiterführt?! Hast du das auch beim Tripper? Hilfreich wäre da eine 2D Navigation, aber ich glaube das kann man nicht umstellen. Gruß Uwe
Update: No further response by Royal Enfield. Last update was 26.07.2024. I consider the app as more or less unsupported. I recommend not to put any more efforts into this. Choose Kurviger for navigation.
I have got friendly feedback from Royall Endfield. The Update - at least for my phone is not yet available.
Dear user, Apologies for the inconvenience and thank you for your patience. We are excited to say that your issue of importing GPX file is got fixed and the latest update is available in Play Store for our app. Please update and try the same scenario. We hope your issue is resolved now. Please revert back to us if needed.
The Royal Enfield users should have a look for updates and I expect the issue to be solved.
If solved, you may give Kurviger 5 Stars and a beer to me and another to the support team of Royal Enfield. ![]()
Edit: I have just seen, that in PlayStore there are two version of the app. One is just called “Royal Enfield App Version 10”, the second “Royal Enfield App - Europe - Version 2.3”.
The first one is updated by Nov, 6th and imports gpx like a charm. ![]()
Dear @Toffel:
Thank you very much. Let’s see if they update the Europe app version as well. The other one is not applicable for bikers in Europe.
Would you please be so kind to address this to royal enfield? Maybe they didn’t even consider the royal enfield app Europe…
Update: I just installed the other App, choose Germany as a country and logged in with my registered email address. Guess that worked well. All my saved tracks are synced. Also my registered motorcycle tripper dash was synced, so no need for a setup of the new app.
Answer from RE Support.
Dear User,
Thanks for you mail. Yes you are correct..! That 1st app is old one and the second one is the new app. Due to some technical dependencies we can’t remove the old app now and it will be removed by soon. There after you never face any issues to upgrade the app.
So using the second app without “Europe” is the correct one. The “Europe” is deprecated.
