Is there a simple way (like ticking a box) so you can import a .gpx route file.
Currently everytime I import and try to use it as a route Kurviger (App and Online) has rerouted parts of it.
For instance it takes you off narrow tracks and routes to faster roads.
Is there a simple fix?
Hi! That is basically what “Kurviger” does. The value of this app is that it tries to be smart, and make a nice route for you
If you import a GPX file, it is most likely a “route”, which has quite a few waypoints, and therefore Kurviger has lots of chances to do fancy things. Even if it is a track, it’s not guaranteed to follow it perfectly. If you want your route to come out exactly the same, you should use .kurviger files, or maybe share your route with your friends (or between your devices) using links or QR-Codes
Also there have been a LOOOT of discussions recently about importing and exporting GPX files, you should check the forum search and read through a couple of topics, I’m sure whatever system you use is already represented here
To be able to simply add a GPX route that someone else has created, without Kurviger automatically re-routing parts of it.
Surely that would be a very useful asset, to make Kurviger a one stop route planning platform. Save buying a dedicated GPS.
If I download a route GPX route to a GPS, the GPS doesnt automatically reroute parts of it !
Hope that makes sense?
Hi, hm yeah, that’s an interesting thought, but remember that Kurviger never wanted to be the “solution for everything”, it’s important to show the user what the page is good at, which is “having a smart algorithm that helps you make a nice route”.
My TomTom 400 strongly disagrees with you on that one
I guess in the end mapping and navigation just has too many facets / devices / purposes / goals to it to make everybody 100% happy
As a result, different routing engines will often produce you another route than the original intended one.
Unfortunately no universal (gpx) file format exists that garantees 100% faithful compatible exchanges.
Some proven file solutions are therefore limited to a few special GPS (cycle) devices or watches or are only supported by the individual app(s).
Example files in the zip contain track turn and Via point info, and with this you can immediately start a 100% faithful navigation. (= To say only are usefull in their respective individual applications) Track file navigation.zip (8.2 KB)
