How to copy routes from one folder to another one?
I’ve various routes in one of my cloud folders and would like to COPY them to another one. How should I proceed as, after having selected all the routes, the only 2 actions available from the “Select Action” button are “Delete” or “Move to a different folder”. I would have hoped to have here also the option to COPY the selected routes to another folder.
But maybe I missed something obvious and if the case, sorry for that.
Best regards
Eric
Could you explain why you would want to mass copy routes into a different folder? Why is moving them not enough for your?
Very simple: I’ve many routes, all in the same folder, that I would like to improve. But, should my changes not be exactly what I want, I would like to simply be able to retrieve the original routes (that I would keep in a different folder to avoid any confusion).
That could be achieved in 30 sec max with the copy option.
I hope context in clearer now.
Thanks for considering this request.
Eric
I am not sure if and when copy will be implemented, but you could also do one of the following:
  • when you start editing the route, save it in cloud under a different name
  • or save the route as .kurviger file locally
  • or even simpler - save the link to the original route in an external document
All of these would give you the option to retrive the original route if needed. None of it supports the bulk operation, but on the other hand - you edit the routes also not as bulk, but one by one.
Thanks for the workarounds but was just looking for something much simpler and straigthforward - the copy option. But will work like that as no other choice for the moment.
Thanks.
