Import error in Kurviger web
Can’t import this route (and several more) in Kurviger. Import in K1, K2 and K3 is working fine.
#1 3.kurviger (30.2 KB)
have other routes which can be imported in K1, K2, but not in K3, same error
This file was not generated with Kurviger and is indeed not valid.
yes thanks, you are right, the fix will come from the other app.
So what’s the use on an IMPORT - function if you can’t im port gpx files from other sources ??
The error described here concerned a *.kurviger file - not a *.gpx file.
Sure you can import *.gpx files …
