one
The message “too many route calculation” appears to early. Playing with the points (no mater which object you use, manual entry) seems always to trigger immediately a recalculation.
three
I have a tested with some gpx-files with a lot of waypoints. Here beyond 350 points, which are even route-points. It is a file from the website of a competitor. The header data for xml and gpx are at least from my point missing and weird, but it is how it is.
On my phone importing this file makes the app collapsing, when changing the count of points, like if I would need ten times of power. Importing on PC-browser is fine.
This is correct. How do you “play” with it? I haven’t seen the message during my tests. It can happen if you did some wild testing before and then just load a new file?
If I either just enter 5 or move the slider, there is only 1 recalculation. Are you clicking the arrow down?
Ok, I can see the issue here, but if you mark the text, you can enter 5. You can’t clear it though, that’s right. We will have a look
In web-browser, I use mainly the slider with arrow down/up, what leads usually to the warning, as I do many clicks in short time.
For web-browser on PC, yes, but is still an very unusal way to enter a value. Normally, I place the cursor and use the back-button. In the app, there is no arrow down. To mark the input in an app is even more unusal.
Other thoughts
Perhaps it could be better to avoid any recalculation, while entering the count, and just let the user do a recalulation, when he has finished his entry (user must press button “Recalculate”).
In the app / on the phone, at least my experience with many points is, that entering / editing the count of points forces unneccesary recalculations, and the power of my phone or my phone´s browser(?) is not able to handle this.
On the phone, perhaps the entry field could be removed in favor of the slider? The slider could even behave logarithmic. When you have a big count, let me say 350, it makes probably no difference to set it to 200 or 250, while when I move the slider to left, it would be easier to set 10 or 15. This is currently very hard to select with the proportional behaviour of the slider.
Just ideas.
Thanks. I would be nice to find a way to import these files easily.
Wenn ich beim Importieren einer GPX-Datei die Anzahl der Wegepunkte verringere und anschließend die Anzahl wieder etwas erhöhen möchte, den Schieberegler als etwas nach rechts schiebe, kommt es zu einem Fehler. Ich habe das mir drei gpx-Dateien ausprobiert.
Noch eine Verständnisfrage. Wann erscheint das Fenster mit dem Begrenzen der Wegepunkte wie oben und wann das Fenster mit dem Optimieren der shaping-Points, so wie hier:
Das hängt davon ab, was in der gpx-Datei an Daten vorhanden ist.
Ich habe mir ein Set von Dateien mit den verschiedensten Export-Parameter gemacht, nur Route, nur Track, usw. und Kombinationen. Teilen wäre nicht hilfreich, weil es sich alles auf meinen Standort bezieht. Nett zum Testen.
Das kenne ich und habe es hier unter Punkt “three” beschrieben, nicht so schön wie Du, aber das war gemeint. Schaue Dir den Thread bitte mal an, ich denke beide Threads könnten zusammengeführt werden. Import Manager - Some uncomfortable things
Natürlich, das war der Zweck der Übung, als der Import-Manager überarbeitet wurde.
Ich habe Dir die Testdateien per PM geschickt. Für alle anderen - die Export-Dateien sind in ein paar Minuten selbst erstellt (z.B. Route um 500 km, ein paar Via und SP setzen, dann alle Export-Kombinationen speichern). Selbst probieren hilft mehr als viele Worte.
