Interesting routing glitch: "Avoid using twice" uses road twice
By chance I stumbled upon a place in italy that seems to confuse the “avoid using same road twice” option. In fact, clicking it actually makes me drive in a circle twice :smiley:
→ https://kurv.gr/ua8eb
If you follow the topographic diagram with your mouse you’ll notice that instead of going to WP1 directly, Kurviger goes around, on the road to the left, then comes to WP1, and then instead of turning around to WP1 it goes in the same circle again :smiley:
This is of course nothing major. It just seems like the “extra curvy” setting really really REALLY likes the road to the left. If go to “curvy” the problem goes away. But I think it’s funny that this also goes away when you UN-select the “avoid using same road twice” (when you do that you see that “extra curvy” really wants to drive on the western route. When you select “curvy” you see the route that I personally would take, from start directly to WP1 then directly to WP2 → so it is technically possible, there’s no one-way-street or anything in the way)
Ich wollte mir die Strecke mal anschauen, bekomme aber die Meldung: " Mindestens einem Deiner Punkte scheinen noch Koordinaten bzw. ein Name zu fehlen. Sollte es sich deiner Meinung nach um einen Fehler handeln, gib uns bitte im Forum Bescheid."
I wanted to have a look at the track, but I get the message:“At least one of your points seem to miss coordinates or a name. If you think this is a bug, please let us know in our forum.”
Uhm… ok I think we have a forum bug on top of this here LOL? The link works when I edit my post and use it directly. But once the forum converts it to a “box” and you click on the box it gets broken. Try the original form:
→ https://kurviger.de/en?point=45.768586%2C10.748223&point=45.771684%2C10.752697&point=45.782355%2C10.751646&point=45.768571%2C10.748416&locale=en&vehicle=motorcycle&weighting=curvaturebooster&additional_weighting=avoid_edges&ch.disable=true&use_miles=false&elevation=true
I also fixed it in the original post
That’s an interesting example, thanks for posting this. Internally, the route from the start to WP1 is calculated first. Now Kurviger tries to avoid the already used roads when calculating the route from WP1 to WP2, this won’t change the route form the start to WP1. There are not many options to take different roads in your example, that’s why it looks like that. If you use only the curvy routing, the results look a lot more sensible. I am not sure if I would call it a glitch though.
Thanks for the note on the one box issue, that seems to be an issue with the forum software.
Haha ok that makes a lot of sense, I guess that gets us into CS territory of tree search and backtracking. If the algorithm hadn’t chosen the route from 0 to 1 yet, then 1 to 2 would be a lot easier to calculate.
And I guess that’s the correct decision, because otherwise the cost would become O(n!) if you have to check every previous path after computing the next one, so yeah, not worth it for this edge case
Yes that’s correct. The process of calculating all possible options is usually referred to as route optimization and would be way more complicated to calculate.
