Issue with planning. Cannot set via points - is greyed out
Hello together
since yesterday i have the problem that i cannot set via points or shaping points anymore. It is greyed out. I set my start point but i cannot set any via or shaping points. I tried it with chrome and edge and also with several notebooks. And i make everything as i did in the past. Can anybody help me please?
greetings
Sebastian
Muss man nicht zuerst ein Ziel setzen, erst dann kann man Sp setzen ?
Yes, you need to place a destination first. You can use extend route to plan a route like that. Pro tip: you can hold the shift button and left click on the map to extend the route.
Thank you very much for the fast reply. This was my fault. I didn`t set the destination.
Greetings
Sebastian
