join testflight
I installed testflight for the beta version for IOS but need a link via mail. Where can I register for that
See here in first post.
where can i find a code for testflight
Just click on the link. It should install testflight, then in testflight you should see the Kurviger app.
Perhaps the code you search for is in the URL? Never needed any code.
testflight.apple.com/join/Y2eMnS3D
You need to click the link twice. The first link click only installs testflight. I don’t know why Apple hasn’t implemented it that testflight remembers which app you wanted to install.
I’m on the way to join iOS testflight for the very first time. When installing Kurviger BETA the installtion want to overright my “old” Kurviger App. Can you confirm this is how it should be and I do not need to worry about loosing data because there may is a bug in the BETA version? Or do you suggest to use a separate mobile phone when using Kurviger BETA?
Sascha
This is correct, unfortunately you can’t keep the BETA and regular app at once.
I would be very surprised if there would be loss of data, as in cloud data was deleted or something like that. We have tested this version before it is released.
When you change between BETA and App Store, I believe Apple will keep the app data as is. If not, it could be possible that when switching you could loose data that is not stored in the cloud, like a recording that you have not finished yet or data in your route history or offline maps t hat you have downloaded previously. So after switching between these versions, you might want to check these.
Our BETA might crash or show errors, while we do our best to have a high quality BETA, mistakes can happen. During the BETA phase we usually can fix these bugs pretty quickly, once released to the app store, it takes longer to get rid of these issues.
If you like to test new stuff, I recommend our BETA.
That is everything I need! Thanks a lot! :+1:
