Curvy and Extra Curvy use highways!?
Currently, both the “Curvy” and “Extra Curvy” settings use (toll) highways. Only the additional setting „Avoid highways“ or „Avoid tolls“ gives me a route without the highway…
Example (“Curvy”): Kurviger – Motorcycle Route Planner & Navigation
Example (“Extra Curvy”): Kurviger – Motorcycle Route Planner & Navigation
Surely there must be a bug in the routing engine?
I didn’t write the algorithm, but I think here avoiding the city is weighted higher than avoiding the highway…
In that case, the motorway makes the most sense anyway; that’s what we have the avoidance feature for if you really don’t want to use the motorway at all.
Yes and no…
I thought that „Curvy“ and especially „Extra Curvy“ avoid highways. And that one should generally work more with curveness rather than avoidances.
… That’s also correct, but to bypass towns, total avoidance doesn’t make sense either. Therefore, there is likely a weighting here that this time favored the motorway. There have already been a few who thought that with „curvy“, every residential street in the city would be included; presumably, they banned the main and express roads in the process.
That is basically correct as well. With avoidances, less is often more, because Kurviger calculates a motorcycle-friendly route even without avoidances. In this case, the short stretch via the highway (instead of through the towns) leads directly to a nicely curvy route. The route calculation simply weighs this up at that point.
