The old ones were some of the last resources of the platform that were still bitmaps.
The new ones are SVG and so simple to resize and change their fill + stroke colors.
Their size is the same, probably the bitmap padding showed them virtually smaller.
Anyway now it’s simple to resize them, however they should remain easy to press.
Edit: we can change their color if there is something more suitable.
Yesterday I noticed a hitch in version 1.14.16. When pausing and resuming the Navigation, the resumption did not work. Both buttons in the bottom left we’re blue.
Only after closing and restarting the app and automatically loading the last route did it work again. I think this is not only a problem of version 1.14.16 since I had this effect already before.
Today, when I “open with” a route via Total Commander (what I always do since I find my saved routes easier with Total commander app) in version 1.14.17, I get this error message.
Yes, mostly it works, but sometimes it hangs. you can press as often as you want to continue, but the route is not continued. I don’t know under which conditions it happens. The “workaround” is closing Kurviger and opening it again. Since the last tour is automatically reloaded (also due to a former request), the workaround is easy. That’s the reason why I didn’t report it yet. I really don’t know exactly when it happens. I had it 3-4 times with this effect. So it is not a big issue. When it happens again I try to figure out what could cause it.
ok thanks, can live with it, ony 1 route concerned
There are street names that are not one word and are larger than the screen width.
So cannot fit them in 2/3 of screen and this panel is optional in navigation settings.
Roger understand,so the same inconvenience as with other single line top panel text displays. Since this occurs very sporadically, it was thought for a while to use a running short text band, as is also known with radiotext. Anyway good luck with the implementation as you like.
For my opinion there are enough options already. With font size and opacity it’s possible to “expand” the map space. Of course, the use of the turn instruction display requires space for it.
I personally never display the turn instruction - just switched it on for the screenshot:
