Very strange thought, like driving with old tires and an inaccurate engine.
Google Play is responsible for its store and does not provide such option.
Sad, anyway thanks for your service and feedback
I agree with Munky, please bring the bubble mode back as a selectable option.
Some people like the new croshair method and others like the old bubble method.
The bubble method is when using a tablet with S-Pen accurate enough and the fastest way to work.
Please try to move a relative large number of vias with the new method, it is really annoying.
For me it would be a reason to stop using Kurviger.
What happened to Location / ‘Smooth Movement’ ?
I could use it till 1.14.11 and in 1.14.14, it is no more available. ![]()
Needs review.
You can use the “Settings | Location | Kalman filter”.
It has smooth movement + reduction of GPS errors.
Will ‘Smooth Movement’ be back again in future? I am very sad about killing it.
I’m using 1.14.11 on an Samsung S6 (Smooth ON / Kalman OFF) and 1.14.14 (Kalman ON) on a Samsung S9+. The Movement on the S6 is much more softer than on the S9.
It may return in the future with improvements for reported issues.
Imperfect features must improve, then could be integrated again.
Like bubble mode, it must first get scroll map and waypoint menu
and reach the feature parity of crosshair mode, before it is usable.
I hope it will return soon.
For my own use, kurviger is a perfect app. The only issue is that it really does not have a smooth scrolling, even on a rather fast smartphone like the S9.
Fortunately, i’ve still got the old version 1.14.11 on my S6 which is exclusively used for navigation. Hope I am able to preserve it from being updated automatically.
Google Play Store starten > Meine Apps und Spiele öffnen > Installiert anklicken > Kurviger anklicken > Oben Rechts auf die 3 Punkte klicken, dort Autom. Updates Hacken entfernen
Start Google Play Store > Open My Apps and Games > Click on Installed > Click on Curvier > Click on the 3 dots at the top right, then remove the check mark for Automatic Updates.
Dankeschön !! ![]()
Ich bin bekennender Smartphone Wenignutzer und wusste echt nicht, dass es so einfach geht. Bei meinem S6 ist keine SIM drin und Wlan aus. Deswegen bisher auch kein Update.
The old tires where better depending on how you use it.
Please !!! make the old version method select-able as an option!!!
In addition, there was no waypoint menu with the old mode.
All of these must first be implemented before considering it usable again.
The old method could only be used with a pen.
I got a pen especially for my tablet at the time. It’s no use on the mobile phone either.
I’m happy to accept the extra click to move a few points, as there are other options that I like to use. I leave the pen at home now
Weight saved.
Kurviger 1.14.15 is available for old owners on their Google Play:
- App: export, import, reset preferences (Pro)
You can export / import (as pref files) and reset (to installation defaults) the app preferences.
Available in “Settings | Application | Preferences”.
- Various improvements
It works, thank you
Klasse Funktion, Danke.
There is a little modification at
‘‘Menu button’’ > ‘‘Settings’’ > ‘‘About’’ > ‘‘Info’’ >
‘‘Menü-Button’’ > ‘‘Einstellungen’’ > ‘‘Über’’ > ‘‘Info’’ >
In 1.14.15 is missing the ‘‘COPY’’ function.
This function for non-experts is very helpful to comunicate the device and software states when there are problems. Makes easier to describe what is to do when comunicating with the forum. Why removed?
Copy on Android needs a review.
This was more useful when writing in the forum on the phone and can actually use the copy.
And the information is very little, it can be handwritten.
