We’ve Moved: Kurviger is Now on Kurviger.com! ![]()
We’re excited to announce that the Kurviger website has transitioned from kurviger.de to kurviger.com!
This is the first step in our migration process, with the forum, documentation, and blog to follow in the coming weeks.
Here’s what you need to know:
All existing URLs continue to work – All existing URLs that point to kurviger.de are automatically rewritten to point to kurviger.com now. This also includes kurv.gr links.
Update your bookmarks – Be sure to replace kurviger.de with kurviger.com in your saved links.
Check functionality – Please verify that your saved routes and links are working as expected - if something doesn’t work, don’t panic, let us know and we will look into this.
We’re committed to making this transition as smooth as possible. If you notice any issues, feel free to reach out – your feedback is invaluable!
Stay tuned for updates as we bring the entire Kurviger ecosystem to kurviger.com. Thank you for your continued support as we grow and improve! ![]()
New links to kurviger.com might temporarily don’t work in the app as expected. If you use the import view and load them as a kurv.gr link or if you transfer them to the app using the Kurviger Cloud or .kurviger file, you are still able to transfer routes. This temporary restriction will be resolved with the next app update, so everything will be ready when the season starts.
As part of this update, we implemented a very often asked feature: automatic language forwarding. If you open kurviger.com you will be automatically forwarded to the language that you set up in your settings.
If you are using a DNS blocker, script blocker, ad blocker, or a related tool, please update your tool to work with kurviger.com as well as kurviger.de to avoid possible issues.
Wir sind umgezogen: Kurviger ist jetzt auf Kurviger.com! ![]()
Wir freuen uns, euch mitteilen zu können, dass die Kurviger-Website von kurviger.de auf kurviger.com umgestellt wurde!
Dies ist der erste Schritt in unserem Migrationsprozess, wobei das Forum, die Dokumentation und der Blog in den kommenden Wochen folgen werden.
Das Wichtigste in Kürze:
Alle bestehenden URLs funktionieren weiterhin – Alle bestehenden URLs, die auf kurviger.de verweisen, werden automatisch so umgeschrieben, dass sie jetzt auf kurviger.com verweisen.
Aktualisiere deine Lesezeichen – Achte darauf, kurviger.de durch kurviger.com in deinen gespeicherten Links zu ersetzen.
Überprüfe die Funktionalität – Bitte überprüfe, ob deine gespeicherten Routen und Links wie erwartet funktionieren – wenn etwas nicht funktioniert, keine Panik, lass es uns wissen und wir kümmern uns darum.
Wir sind bestrebt, diesen Übergang so reibungslos wie möglich zu gestalten. Wenn du Probleme feststellst, kannst du dich gerne an uns wenden – dein Feedback ist uns sehr wichtig!
Bleibe auf dem Laufenden, wenn wir das gesamte Kurviger-Ökosystem auf kurviger.com bringen. Vielen Dank für deine fortwährende Unterstützung, während wir wachsen und uns verbessern! ![]()
Neue Links zu kurviger.com funktionieren in der App möglicherweise vorübergehend nicht wie erwartet. Wenn du die Importansicht verwendest und sie als kurv.gr-Link lädst oder sie über die Kurviger-Cloud oder die .kurviger-Datei in die App überträgst, kannst du die Routen trotzdem übertragen. Diese vorübergehende Einschränkung wird mit dem nächsten App-Update behoben, sodass vor Start der Saison alles bereit ist.
Im Rahmen dieser Aktualisierung haben wir eine sehr häufig nachgefragte Funktion implementiert: die automatische Sprachweiterleitung. Wenn du kurviger.com öffnest, wirst du automatisch zu der Sprache weitergeleitet, die du in deinen Einstellungen festgelegt hast.
Wenn du einen DNS-Blocker, Skriptblocker, Werbeblocker oder ein ähnliches Tool verwendest, aktualisiere bitte dein Tool, damit es mit kurviger.com und kurviger.de funktioniert, um mögliche Probleme zu vermeiden.
