Hello friends.
I planned a route with Kurviger and shortly before arriving at the hotel I was supposed to ride over a pedestrian bridge. The correct approach would have been from the B107.
https://kurv.gr/TRPQu
I checked the data on OSM. It is indicated as a pedestrian bridge, vehicles: no
What went wrong there?
Greetings, Nico
Hi Nico, turn off the avoidances helps. Your route:
Same less any avoidance:
https://kurv.gr/YfXth
In general I strongly recommend to turn off all avoidances (maybe except gravel roads, but those only on a low level) and let the algorithm do the job - this worked at least at my side since the launch of K3.
Ok. But this is strange. Because of the avoidances of gravel roads the system chosses a wodden pedestrian bridge?
But it sounds plausible and i tested it also. You are right.
The original access is via the street and not the gravel route:
May this has to be changed in OSM.
Regards, Nico
The change of the bridge from highway=track to highway=footway has been done 22h ago, please check history of
In a few days Kurviger will consider this change and not use this bridge any more.
Remark: You can see the date of last update of Kurviger routing data in settings / debug information (OSM timestamp).
