Losing cloud data
I’m changing android phone to apple.
So I have to stop my android subscription and make new on apple.
But what about my routes favorites in the cloud, do I loose them?
Or are they connected to my email?
Your subscription is valid for all platforms, do not cancel it.
I have to cancel. As if I not cancel, I cannot pay the renewal. As by the apple there is no option valid for renewal or paying.
if I’m wrong please explain
You also want to cancel/delete your Google account? I guess you could keep the Google account so you can pay the subscription. You should be able to install Kurviger on your Apple devices and to login the way you do it on Android. Tested?
If you do it the hard way .. You can export / import the favorites folder by folder. You can export/import each route one by one (in kurviger file format). The Tracked Rides - you can export one by one as gpx. But it is not possible by import the exported gpx to folder Tracked Rides again.
There is for now no mass-export/-import. So I would keep the subscription active.
Edit: Just for clarification. When you uninstall Kurviger on all your Android Devices, the subscription is still active - and you pay as long until you finally cancel the subscription. In this case, Google is just the service-provider for the payment.
This is at least my understanding. Just use Kurviger now on Apple and keep paying to Google-Services.
This is correct @Sjaak65 - unless you really want to delete your Google account, just keep your subscription active and login with your new device. You don’t need to switch to an Apple subscription.
We don’t recommend this, but switching is possible, if you cancel your existing Google Play subscription and sign up for an Apple subscription, once the Google Play subscription is inactive.
Yes :+1:
Ok thanks, using Kurviger on the iPhone and that works, so no issue
I will look on iPhone about payments.
Thanks
You don’t need to do this.
If you want to cancel you current Google Play subscription, you can do this on the web here: https://play.google.com/store/account/subscriptions
Just enjoy the app, all good :slight_smile:
