Map update
Looking on the download site for the offline maps it looks like they have last been updated in february this year. This means they would be 3 months “old”. Is this correct?
How often are they normally updated? I believe to remember that it used to be every 2-3 weeks.
Thanks,
Tom
Usually the maps should be updated monthly, so they usually shouldn’t be older than 2 months. Due to the introduction of the routing files, the process is currently a bit slower than usual, but I expect that we get back to monthly updates soon.
The routing data of the Kurviger server is updated weekly.
Jus a brief update, the latest map update went through, so new data is available.
Thanks for the update.
Hi all,
many offline maps are from 11/20. When is a map update provided?
Thanks
GraphHopper routing files are no longer needed.
Their production can be stopped and removed from the server.
Thank you :motorcycle:
There are also many offline map providers compatible with the app.
It will be much more convenient when you can also use their map styles:
