die app zeigt auf Wunsch die max. erlaubte Geschwindigkeit an. Wusste gar nicht, dass es 150 km/h sein können ![]()
The OSM data for this road will probably not be correct.
It’s correct and says “none” because it’s a highway (Autobahn).
The KurvigerAPP shows in this case “150 km/h” I guess. Fast enough for me …
Αpp shows the max speed as included in the calculated route.
If a segment in the calculated route does not have max speed,
then it displays “–”.
There is a technical limitation on the server side, so we might store 150 instead of none.
