I can also confirm following:
Deleting all WPs one-by-one
- load any route
- delete all waypoints one by one, effectively deleting the route
- start and end follow mode
last Start- and End-Point (before deleting them) reappear
no error message is displayed im my case.
Leaving only Start-Point undeleted
- load any route
- delete all waypoints one by one, except the Start-Point
End-Point and the route will reapear
Delete route, then add Start-Point
- load any route
- delete the route using the dedicated menu option
- place only the Start-Point on the map
Start-Point will disappear
@boldtrn I still need to test how it behaves with the AA, but if route keeps reappearing when the follow mode is stopped on AA display - it would be undesirable (prompting the user to take action on the phone to remove it again).
I see reappearing deleted End-Point (
and
), but also dissapearing Start-Point (
) as (minor) bugs
that should be fixed.
After all, I’m still trying to decide whether I should go with Kurviger,
Are you still in the free trial period? Then maybe the developers would need to have a closer look if this is causing the error message to appear.
