Minor offset at intersection triggers voice prompt „Turn right“
Unfortunately, I don’t either. Maybe you have to experience it to understand.
Here from my area. With the tolerance threshold, I wouldn’t get an announcement - but I think it’s good. When I arrive at the stop line, I only see a house in front of me and not yet where “straight ahead” continues (first the curve, then quite steeply upwards, no view of the road yet). With the announcement, I know to position myself “left”.
Nah - I can read:
Besides, the Kurviger app will show it just as clearly:
@ zaphod_42
There, (oh man and then 10 characters …=
well great if you can do that :sweat_smile:
have no idea what’s your problem, other than that you couldn’t accuse me of not being able to read, I don’t even need a satnav at that point.
but a 5m tolerance makes no sense, but apparently you don’t understand my posts :+1:
The situation there is not comparable because the roads don’t zig-zag like at @roy’s intersection. I definitely agree with you that it’s a fifty-fifty chance whether to turn left or right, especially for someone unfamiliar with the area. The “5m” rule wouldn’t be relevant there, imho.
The only thing that helps—even for the intersection reported by @roy—is to look at the map. Purely based on voice navigation, it’s just fifty-fifty. And the fact that sometimes an earlier announcement would be useful was also discussed recently. A quick look at the map to see what’s coming up ahead is a must.
Whether a 5m tolerance makes sense… well, BRouter at least seems to do it that way or similarly. There must be reasons for it.
Here it was an obvious OSM error. I went ahead and “straightened out” the zig-zag at the intersection.
From @roy’s perspective, everything is correct. As a user, he is annoyed, takes the trouble to report it, and of course, from a user’s perspective, a 5m rule is useful. Now he knows that if it happens again, he should report it.
From my perspective, introducing a 5m rule because of an OSM error is oversized. If there are many more situations like this (as he says), then I am wrong. Then so be it.
@Kira Could you please check internally. I modified the intersection 3 days ago. The routing is correct, but the map is not up to date yet. On OSM, the road layout is already correct. Thanks. Kurviger – Motorcycle Route Planner & Navigation
So the last map update unfortunately failed, supposedly due to a power outage at a university where a server is located that provides us with data. I’ve now triggered another update without this data and hope that the server will be available again soon.
Relevant XKCD for this: xkcd: Dependency
