Navigation shows imperial units when set to metric (Android)
Problem
Even when I set Kurviger to Metric (length = metric), the turn-by-turn navigation distance still showed imperial units (miles).
This happened on:
  • Android
  • Phone screen (not Android Auto)
  • Both Live Navigation and Simulate Navigation
Every thing else remained metric, but the turn-by-turn screen showed miles.
What I tried
  • Restarting the app
  • Restarting the phone
  • Verifying that new and old routes both affected the turn-by-turn screen
Cause / Workaround (based on my findings)
Switching the app language affected the navigation unit formatting:
  • When the app language was English, navigation distance appeared in imperial.
  • When switching the app language away from English (Spanish to be precise), navigation returned to metric.
  • When switching back to English, the navigation remained metric.
Final Solution
If you see miles in turn-by-turn navigation while using metric settings, try doing the same as me.
Request
This seems like a unit-formatting bug related to the language setting. Please consider fixing so units stay consistent regardless of language (when the metric setting is enabled).
Thanks for reporting, I will double check :+1:
