Best way is to use the search function and add the result as point like needed start / end / VP / SP.
Then it will be sorted into the list as best part of the route. In most cases that’s ok.
If not, move it up or down in the list of waypoints then.
As (+) between each inside the WP list: How will you be sure to be at the exact entry before?
when planning my route, I would know where the additional waypoint needs to be added. with the (+) I could position it faster and easier than via the search function. That function was very convenient (in the past).
Can you explain why this is? Now this should be about the same, or even less clicks / manual work, if you want to order the address logically into your route. For roundtrips sometimes the automatic ordering can fail, but typically this should work out of the box.
