Edit Moderator:
Original text deleted as it was off-topic.
Edit Moderator:
@Guenniguenzelsen you know that location in person?
Do you mean the encircled traffic sign?
In this case it can be solved with a turn restriction
In this case there is an exception for bicycles:
To add this exception click on the turn restriction.
… and add the exception for bicycle.
As a last step, you should mark the note as “resolved”
I did not make the actual change, so you can practice yourself ![]()
