I’m a new user of Kurviger, but I don’t hear spoken instructions. I’m using a Cardo headset, set the volume, installed a Tts engine from Google incl. dutch language pack. Still the app remains silent. Even a t home, just the phone and in simulation mode no sound. I don’t get it, my Google Maps works fine on my Cardo.
Hoping to hear from you soon.
The spoken instructions can be heard via phone speaker if you do not use the Cardo Headset, I assume?
Have you tried changing the “Voice Output Channel” found in the “Settings>Navigation”, while connected to the headset?
Sometimes just the volume of the used channel is set very low and you need to increase it while the channel is used (instructions are spoken) or in the advanced volume setings on the phone.
Also, posting the “Debug Information” found at the bottom of the “Settings” menu may help the developers check if there is an issue with the version that you are using.
Hello and which Kurviger subscription have you booked?
It’s a language issue, all other languages are working properly. Only the Dutch remain silent .
Mhm, ok, this is unexpected. If you have the TTS and the language installed it should work. Is the Google TTS the default TTS in your system?
If it is the default, you could double check if there might be a different language pack for Dutch (maybe there are multiple one, that feature different language codes).
I double check my settings, a Samsung tts engine was shown. I changed to Google and now it works fine.
Thanks for your support
