Notify a bug: The amount of routes within the folder incorrect
I have 2 folders. Folder A and folder B. In each of them I have 2 routes. So in total 4 routes.
However, it states that I have 3 routes in folder A and 1 route in folder B. As you can see in screenshot, 3 and 1 route. but within the folders I have 2 and 2 routes.
Hi @Ahmet,
Thanks for reaching out with this! Can you give us some background info so we can better understand the bug? Since when has this been the case? Are the routes new in the folders? For example, did you just move or save any routes?
The fix for you for now: you can move the routes into a new folder and just delete the “broken one”.
Hi Kira, thank you for your reply.
I am new to Kurviger, since yesterday I started creating routes in 2 different folders.
in the beginning it was fine: until I accidently created a routed in the wrong file. So I choose to move the route to the other file. since then, it shows that there are 3 routes in the file while it’s only 2.
I just created new folders and moved the routes to the new folders and now it’s fine.
I also did a backtest. I moved a route from one file to another and move back. this time, there doesn’t seem to be a problem. the numbers are now correct. So i don’t know why the numbers where incorrect in the first place. I am not sure if has something to do with me creating the routes on laptop and moving it on my phone.
anyways, thanks for the reply
