Open map links in new tab/window - Kartenlinks in neuem Tab/Fenster öffnen
Hi all,
The “Show on…” links in the right click menu all open in the current window/tab.
Probably many already know, but I found out that if you click on “What’s here” the same links are then available in the “Detail Information” panel under “Further Information”, and they can be middle clicked/right clicked to open in a new window/tab.
hope that may be helpful, cheers
Deepl > German
Die “Anzeigen bei…”-Links im Rechtsklickmenü öffnen sich alle im aktuellen Fenster/Tab.
Wahrscheinlich wissen das viele schon, aber ich habe herausgefunden, dass, wenn man auf “Was ist hier” klickt, die gleichen Links dann im “Detail Information”-Panel unter “Weitere Informationen” verfügbar sind, und sie können mit einem Mittelklick/Rechtsklick in einem neuen Fenster/Tab geöffnet werden.
Ich hoffe, das ist hilfreich, danke
What browser do you use?
With Firefox (on Linux) they open in a new tab.
Same with Chrome (on Windows 10).
I think a browser can overwrite the default behaviour. The website is explicitly asking the browser to use a new window or tab. The right click menu uses a different technique to open these, so it can happen that these actually behave slightly different.
Ah, very interesting. yes it does open in a new tab on Opera/Android too.
I should have tested more thoroughly.
I’m using Firefox on windows - might be one of my extensions. I’ll do some testing.
Nevertheless it was or is a helpfull hint for users with the same effect as you had when using kurviger website with a certain browser or extensions.
