I learned that it is possible to create specific colors for each (track) overlay - wich ist great!
But I don’t like that tracks are showed as dashed lines. There ist no possibility to change them into normal lines?
Would be a comfort if you’ll show many tracks at the card.
Idea - a widget like Größe (Size), for length of dashes, so from short dashes over longer dashes in several steps to closed line.
Everything as closed line would probably nit fit, as dependant on color of the map, xou will see nothing anymore. Also in case of overlays in the navigation.
Yes, currently, you can not change it. The idea or proposal was to introduce something like this to also change the length of the dashes from small dashes to closed line.
