Permissions: Background Location
Hi, today was the first time out with the 3.5.10 version and for the first time ever I get get the following display:
Kurviger has all permissions enabled. If I stop and redo the permissions, it works as expected, until I switch the bike off. Restarting, I get the same message displayed.
This did not happen with 3.5.9.
Any ideas?
Edit: If I change location permission to allow all the time, it works. My default is to have “while using the app” and this has been AOK up to now.
Thanks,
John
I encounteted a similar problem, then I realized that “allow all the time” is not even offered as an option during the installation on my S10e and I had to go to settings and set it there manually.
I think I found the problem. Blitzer.de, (CamSam), had location turned on all the time.
Put it back to “only while app is in use” and that has cleared it.
The message is a bit ambiguous. It seems Kurviger cant get the location if another app has location services “in the foreground” - set to always on.
As you were.
J
Thanks for the update. That sounds very wird though. I am happy that it works now :+1:
