I probably missed something in the latest updates of the iOS app: when I add “Shaping Points” in the preview of a GPX file to adjust the route, it has no effect whatsoever. In the PC version, however, it works as usual.
Hi @Rsandri58,
What exactly do you mean by that? The SP isn’t even being set for you?
When I import a GPX file, the route proposed by Kurviger often doesn’t match the one in the GPX file. To fix this, I usually start by using the “Optimize Waypoints” option; if that’s not enough, I make manual adjustments by adding “shaping points” along the red route line to force it to follow the desired path. For some time now, I haven’t been able to do this—whenever I click on the red route line, all that happens is that a blue/white dot appears, and nothing else.
I can reproduce the Problem on iPhone SE.
OSM date stamp: 11/29/2026
Version: 3.6.8
Device: Apple - iPhone12,8 - iOS: 27.2.1 - WebView: 27.2.1
App-Version: 3.6.8 - 13467
Screen: 375 x 667 px - 2dppx
On Android it works without problems - same Route, same section.
OSM-Datumsstempel: 28/11/2026
Version: 3.6.8
Device: samsung - SM-G970F - Android: 12 - WebView: 158.0.8127.46
App-Version: 3.6.8 - 8330
Screen: 360 x 760 px - 3dppx
