PROBLEM: Map disappears partially
Last sunday on a Black Forest Route I noticed, that the landscape (the map) disappeared partially, i.e. obviously one or more tiles (pic 1).
After several minutes while cruising it came back (pic 2).
If I am not wrong the offline (!) map of germany was opened.
What could be the reason?
If you look closely, you can see that there is the “OpenMapTiles” copyright on the bottom. This means, you used online tiles ;). The first picture also shows that you had no reception, so the tiles could not be loaded.
Cheers,
Robin
It means I used ONLINE maps by accident?
Hmm - don’t know why (perhaps because I played a bit around with the app for testing in the last days) - sorry then for unnecessary asking - and THX for the hint!
