Problem sharing folders and routes
I am trying to share a folder and routes with another subscriber but their email is not recognised.
Hi @mgcreagh,
Can you please explain what exactly you do? If you follow these steps and the e-mail you type in is the e-mail of an existing Kurviger profile, it should work. Please double check the e-mail address again.
I worked it out. I have to make the folder Open before I can invite someone.
Glad it’s working now! Could you please briefly explain the confusion again, since you’re not the first person to ask: If you invite someone directly using “Invite someone” and enter their Kurviger email address, you don’t need to adjust any settings under “Access settings.”
So, you probably took the other way, wanted to share a link and then wondered why no one could access it?
From My Routes I clicked on Private under a Folder and then Invite someone.. entered their email address and got the pink error box No Kirviger user could be found for this emIl address.
Under Access settings (currently Restricted) I chose Open.
I could then go to Invite Someone, enter their email and send.
They received the message and got the route.
Private changed to shared.
Did you enter the email address which your friend used to register with Kurviger?
You can not use some random email. To use this fearure the email must be registered with Kurviger.
Otherwise you must give access to anyone, as you did.
My friend used his own email address to subscribe. We do rides in Thailand and I am planning the next one. I have a solution to share routes without having to send them via Whatsapp. My friend is nearly 80yo so I don’t want to fuck him around tech. We have found a solution that works.
