Recently not able to download new routes from cloud
After using Kurviger successfully for over 2 years, I’m unable to load a new route from the cloud.
Hi @m.unsworth46,
Thanks for reaching out!
It’s possible that something just got “stuck”. Please try deleting the local data: Settings → scroll down → Delete local data.
If that doesn’t help, please give us a little more background information so we can help you better: What exactly happens when you try to load a route from the cloud? App or Website? If the problem occurs on the website: is that so for every browser or only in one? Since when does it happen? What Kurviger version do you currently have (You’ll find your debug info at the very bottom of the settings.)
Hi Kira
All things are pointing towards the phone I use for navigation, an iPhone 7 Plus which only runs IOS 15.8.8.
Unless I am mistaken and there is a fix?
Mick
Our minimum supported iOS version is 16.4 for quite some time. So I am guessing you are running a very old version of our app and it might indeed be the case that it is not compatible with our cloud anymore.
What you could do as a workaround is to open Kurviger in your browser, use the cloud there and then download a .kurviger file or try to share the URL to the old version. I am not 100% sure this will work, but might be worth a try.
