Route sends driver down oncoming off-ramp near Bormio
I set up a route from Pedenosso (Italy) to the southern Edge of Bormio (Italy). If I want the route to avoid the town center and use the SP28 it sends you down an oncoming (one-direction) onramp at Santa Lucia instead of proceeding through the tunnel to the roundabout as it should. Yes, you can force the routing down the correct path with another waypoint, but it seems dangerous that the oncoming traffic’s on-ramp is the default routing.
(Had to do it like this since I can only attach one photo, you can open the photo in a new tab to enlarge it)
I extracted the problematic section of the route:
Max
I made the correction (one way : yes) for the last section in OSM, it should be effective on Kurviger in 2-3 days.
The change worked. Now it is sending you to the tunnel as expected.
