Hi all, this is almost certainly a small error in the OSM data, right?
But I can’t figure out how to fix it. It probably has to do with the turn restrictions, right? It seems that the node says “only straight on” and “only right turn”, that can’t be… But Lima-City doesn’t even output a warning, so…? Is it something else? A little help would be appreciated
Ich glaube, dass ich den Fehler gefunden habe.
Bin mir aber nicht sicher
Auf der “Hundsrückhöhenstraße” steht “nur geradeaus” (Ost-West und West-Ost)
Soweit so gut:
Gleichzeitig steht aber “nur rechts abbiegen” (von der “Hundsrückhöhenstraße” in den südlichen Feldweg)
Gemeit ist es vermutlich anders
“nur rechts abbiegen” vom “südlichen Feldweg” zur “Hundsrückhöhenstraße”
I had a look here. I think, as Manfred said, the issue is the only right turn restriction. My best guess is that from and to of the restriction are in the wrong order.
All good, I was just confused why you repeated it
Ok are we sure that both right and left turns are prohibited as you set it now? It’s probably correct, seeing that coming from the other side it’s also only straight on
Ah thank you, the easiest way is indeed the online editor.
If you click on an intersection point, then a window of your intersection appears on the left side.
On top of this window is a hint: “click on the from way”
