Routing not following slip lane
Hello, I discovered a routing oddity. Please see this screenshot:
I would expect the routing to follow the the slip lane here.
Here’s a link to the route: https://kurv.gr/x2csA
I looked at the slip lane in Open Street Maps, and as far as I can tell it looks normal. In particular the lane is joined up to the road.
Probably is the similar (GrpahHopper) issue/ bug as was reported here.
(A similar routing result has recently been reported as solved in OsmAnd.)
Strangely enough, the routing works in the “fast and curvy” setting.
The route guidance is strange anyway, you should definitely not drive like this!
According to Google maps, you should be able to turn left without making a loop:
