The route
is crazy - seems to be the N88.
I think it is a GraphHopper bug: If you plan that route on OSM with router Auto(OSRM), it works:
But using Auto(GraphHopper) it is also a problem:
The route
Thanks for finding this. There was a turn restriction in OSM that seem to have collided with the construction road that was added there recently. I removed the restriction and should be working again in a few days.
OSRM does not consider turn restrictions.
Thanks a lot - I did not consider turn restrictions
I have to admit that I spent > 1h to investigate it, but failed and desperated - next time I will check for turn restrictions (I am quite sure
Good to know!
You are right (as expected
): Now the routing works fine ![]()
Thanks!
