Sorting / Sortierung
Englisch unten.
Mir ist unklar, wie die Sortierung innerhalb der Cloud erfolgt. Ich kann u.a. das Datum als Sortierkriterium wählen. Aber nach welchem Datum wird sortiert? Datum der letzten Änderung (funktioniert nicht), Datum das im Routenname steht (passt auch nicht). Also, was kann ich machen, damit die Routen in der Reihenfolge stehen, in wlecher ich sie fahre? Danke
It is unclear to me how the sorting takes place within the cloud. Among other things, I can choose the date as a sorting criterion. But what date is sorted by? Date of last change (doesn’t work), date that is in the route name (doesn’t fit either). So, what can I do so that the routes are in the order in which I take them? Thanks
I use a prefix and sort by names.
D01_first-day-trip-name
D02_second-day-trip-name
D03_…
I tried to fix it the same way using A then the date, B then the date but it was sorted chaoticly
OK, I tried it again and used the alphabet with a underline behind. I did it with all routes and after that I sorted. Now it works. Thank you for your advice
If you wish to use a date as a prefix of the route, make sure you use a format like yyyy-mm-dd or similar, where the biggest time unit (i.e., year) is first and smallest (i.e., day) the last.
Sorting by date is using “last modified” date as a criterion.
