Hello. I’m not sure if this has been reported before, but I’ve noticed that here in Australia the turn diagram in the top left of the screen often shows a upcoming turn as the opposite direction than required. For example, a roundabout with a required right turn will show as a left hand turn going the wrong way around the roundabout. We drive on the left so I’m not sure that your diagram is optimised for driving on the right ![]()
Hello,
can you share an exemplary route/section where this occurs, so that the team can investigate?
It’s the wrong site
- but Kurviger knows that!
As far as I remember, in Australia I always had to turn left to enter and to leave a roundabout.
Here an example with several roundabouts in your country: https://kurv.gr/XCJgM
Hi. Just to be clear… The map displays correctly. It is the preview in the top left corner whilst navigating that is wrong. I’ll screenshot an example out on the road.
You don’t have to go on the road to make screenshots, just make a two point route on the intersection where it occurs and simulate the navigation. Then you can take the screenshot from the simulation.
I used to live in Sydney and have tested Kurviger extensively in Australia. This should usually work as expected. There are some roundabouts that are tagged incorrectly in OSM and possibly some minor issues on our end as well, but I’d say it should work fine in most cases. If not, please provide samples ![]()
