Speed indicator
Can the navigation app’s speed indicator be changed?
The bottom corner is a bad place, the top would be much more practical.
Many drivers only drive according to the speed display on the navigation app. The carplay screen often appears in front of their own dashboard. This is why I often use alternative navigation apps because it is a big drawback, at least for me. Is such an update possible?
Hello @Tuomas_Holmqvist,
I understand that this is important to you. However, the position of this element can’t be freely customized. We focus on making the default layout as efficient and user-friendly as possible for everyone, rather than offering individual customization.
That said, your feedback isn’t lost - we actively collect and review user input like this when making decisions about future improvements. :light_bulb:
The fields are predefined by AA. According to Reddit, the AA code contains hints that it could be done differently, but it’s not officially released and not available for application developers.
There’s speculation that it will be implemented sooner or later, but whether it will simplify things remains to be seen.
Die Felder sind von AA vorgegeben , im AA Code gibt es laud Reddit zwar hinweise das das auch
anderst gehen könnte , aber es ist nicht Freigegeben und nicht zu nutzen für Applikationsentwickler.
Es wird spekuliert das es über kurz oder lang kommt , aber ob es die Sache vereinfacht
wird sich zeigen dann müssen .
How can I see the speed on the app in Carplay?
Do I need to activate it somewhere? I do not see it on the display?
thanks
Robert
Hy,
Yes look under options.
DlzG
Yes,…
Thanks, found it under:
Settings => Navigation => Additional information displayed
