Sprachausgabe
Hallo und ich kann das mit meinem Samsung und Sena so nicht bestätigen.
Wenn du es noch nicht gemacht hat aktiviere in deinem Android Telefon die Audioanhebung.
Text-zu-Sprache
Bevorzugte Engine → Google und unter Optionen die Ausgabelautstärke aktivieren
Hi Hobbyfahrer,
danke für den Tipp wird getestet, feedback kommt.
Hello,
for navigation I used my Motorola G5gplus.
The Curvy Tourer + with update from 04.09.23.
I imported planned routes with the cloud function and started the route. In the Sena SRl mesh I then heard “off we go” still and then nothing more. Then as soon as I stopped and clicked the app again, the location display jumped to the current location. I.e. the navigation did not run along. I put the smartphone in the scooter compartment while driving and only wanted to hear the announcements. Unfortunately, I did not succeed in this. What else can it be, the following settings I have changed.
Screen saver from 2 min to 30 min is set max.
Battery was charged and not set to save, so the app can also continue to run in the background.
Sound is on, otherwise I would not have heard the first announcement.
What comes to mind now, can it be that the hard plastic prevents the GPS signal to receive, where Googlemaps runs so without problems.
Have you given the App the permission to always get your location?
Here you also might find helpful hints:
https://docs.kurviger.de/start?id=app/faq/app_is_stopped_in_background
thanks, i found the solution with these discription.
Das Problem habe ich auch. Bis jetzt konnte oder wollte niemand helfen
Hallo Jörg,
willkommen in unserem Forum.
Lies Dich gern in diesem Beitrag ein und ich bin mir sicher, dass Du Deine Lösung finden wirst.
Alternativ schau Dich auch gern in diesem Beitrag ebenfalls noch um:
