see wp1… Kurviger doesn’t want to use it, it guides over the french border via D35a instead of using the tiny unnamed road which is even not a gravel road but asphaltic.
Also sometimes Kurviger also rejects to use temporary stoppages, but it is not visually shown why this happens. Is it possible to show why Kurviger avoids a road temporarily, for example by symbol for road construction zone or Snow symbol for temporarily closed alpine passes?
Also if there is a forbidden transit and I know it is possible to use it with a motorbike, how can I force Kurviger to use that road anyway?
Kannst Du bitte mal das Stück als Route verlinken?
Can you please link the piece as a route?
Das wird nichts werden https://kurv.gr/eUYqS Punkt 2(mein Punkt 2) ist als highway=track eingetragen, bedeutet ein Wirtschaftsweg , der u. a. hauptsächlich für die Land- oder Forstwirtschaft genutzt wird.
Du kannst es mit dem Brouter und dem Profil “enduro” versuchen App: Offline routing (BRouter) - #29 by luckytown. Oder Du fährst ohne Routing da lang.
That won’t work https://kurv.gr/eUYqS Point 2 (my point 2) is registered as highway=track, meaning a road, which is mainly used for agriculture or forestry.
You can try it with the Brouter and the profile “enduro” App: Offline routing (BRouter) - #29 by luckytown. Or you can go there without routing.
Was mich auf die Idee bringt kurviger als Fahrradnavi zutesten. Danke Wolf.
Which brings me to the idea more curvy than bicycle navigation systems. Thanks Wolf.
@Tom if you know this road and know that it is allowed to be accessed by motor_vehicles, then you can add access=yes in OSM. Looking at Mapillary, it seems like this is correctly tagged as track, but it’s hard to guess from the image: https://www.mapillary.com/map/im/MVFM_8UFngxeRcGjtTsKkA
