Dear,
The Lixhe bridge in liege is closed unitl 28 of august.No matter what i do even if i add a waypoint it keeps sending on the bridge.
How can i fix this?
Kind reagrds,
Maarten
Hi @Maarten_Cuppens,
Try setting shaping points on the bridges below like this. This should help?
Hi Kira,
Thanks this works.
But when i generate a ride, why does it still takes that bridge? beceause this whas a generated route?
Thanks in advance!
Kind regards,
Maarten
Talking about the right bridge?
According to the available data, one is potentially closed. Kurviger accept routings thrue potentially closed streets.
Otherwise you can not plan routings in the high mountain.
Exactly as @Hampic says: in our map data this section is marked as potentially closed and thus Kurviger doesn’t exclude it in routing but shows it as a red section on the route.
When you activate the feature to avoid closures and a closure is missing, you can always report this to TomTom using their feedback tool if you like: http://www.tomtom.com/mapshare/tools/
