When you click on a via point or a shaping point in the website, it shows you the time and distance to that point, which is very helpful. However, if you click on the end point, it doesn’t show you the time or distance to that point. It would be very helpful if the time and distance of the end point were shown too.
Yes, It would be very helpful. ![]()
Thanks for the proposal, yes that is indeed planned in the future ![]()
Great, that is good to hear! ![]()
In the meantime as a work-around I notice that I can collapse the waypoint list to see the total time and distance.
Yes, you should be able to see the total time and distance even if the list is expanded it should be at the bottom of the page?
I think the time and distance weren’t showing at the bottom of page when the waypoint list was expanded, but I looked again now, and they are there now. Maybe I got confused.
It’s easy to miss
But it should have been there from the start ![]()
Hi All!
Would it be possible to add the display of the estimated time elapsed and the distance in between each waypoints of the road during the planification, without having to click on the particular waypoint?
Also maybe helpful would be the possibility to define a starting time in order to see a schedule along the route, and maybe the possibility to add a pause time at a waypoint (set by default at 0 minute).
This would be a great help to planify a trip with pause for coffee and lunch stops.
Thanks for reply and for your fantastic app!
Best regards.
Jo
