Hallo, during navigation is POIs to small. It is dificulty read on display next POIs if you ride. I cant identificate if the POI is petrol station or cementary or what kind place. I use iPhone 14 Pro.
Hello Radoslav and welcome to the forum!
Which POIs would you need to be better distigishable and how much bigger they should be in your opinion?
I am personally quite happy that the gas stations are violet and slightly bigger than the others and parking lots are distinctive colour and shape. Those are the ones I need the most while riding. I would not mind them being slightly bigger (e.g., 20%) on the phone screen, but I would not need to have bigger cemetaries, trash cans and similar.
If I remember correctly, it is currently not possible to display this larger, as the POIs are embedded in the OSM map.
For petrol stations, the petrol station search is almost perfectly solved and you don’t really have to search for it on the map anymore.
Hallo, for me is important same POIs, parking you can see perfect, becouse mark is different to other. Petrol station is inside of circle, so on map you can see like other ( cementary, church etc.) If you drive, it is hard to identificate.
Petrols stations are already larger than the other pois and are the only magenta colored POI. So this can help to identify them quicker. Overall, using the search along the route would be your best bet
