Hi Guys,
I’ve a question before I search and didn’t find the point. Is it possible to show the Track of the route during the navigation.
I use the Track of during guiding for the best orientation.
Thx
Winnie ![]()
Hi Guys,
Thx
Winnie ![]()
Try searching for the keyword overlay
Hi @BlackDriver,
You can put a track on your map (that is also visible during active navigation) by using Map Overlays. If you start the follow mode, you can follow it along during your ride.
I don’t understand the question.
The track mentioned is the route that was calculated, after all.
Two lines on top of each other makes no sense.
That might make sense if you leave the route with recalculation enabled and still want to see the planned course, which the overlay would then show.
Or, as Kira suggested, if I want to follow a track without route instructions, i.e., without a route (in follow mode). But I wouldn’t call that „during navigation“.
Perhaps you could describe in more detail what you mean, @BlackDriver.
Thx Kira,
that was helpfully and solved my concern
Thx
