When Y export a route to Basecamp it shows only a straight line without following the roads. When Y include waypoints to the route the exported version shows a bit the route on the map roads but it also shows the route on the map withoout following the road in the installed maps in Basecamp. Y guess this is caused by the fact that the maps are different in between Kurviger and Basecamp. Can somebody help me out with this?
Hi, I recommend: Do not use basecamp, just put the files exported from Kurviger in my converter and copy the result via USB to Navigator:
Help:
