Uncaught Syntax Error: Unexpected Token (
Hi. Just removed the old Kurviger and installed the new. In getting the above error message. No ad blockers etc. Everything is up to date. Running Android 7.
Kurviger runs in the Chrome browser fine.
Any suggestions welcome.
Cheers
Please have a look here: Somehow Kurviger does not Behave the Way I would expect it, what can I do? [Kurviger Knowledgebase]
This is most likely an issue with the webview. Maybe you can share more info about the device?
Thanks.
I’ll certainly take a look.
It’s an aging Doogee S60 rugged smartphone.
Cheers, Paul
Ah ok, got it, by any chance, did this device not come with Google Play installed or did you install a custom rom?
What you can try is to install a different webview, like this: https://play.google.com/store/apps/details?id=com.google.android.webview.beta
You can then change the default webview provider. I am really not sure if this fixes your issue, but might be worth a try.
Google apps all run fine. I use Chrome as my browser, Gmail, Maps, Photos, etc.
