(Text in deutsch unten…)
A question for those interested in this feature - do you:
- already own a controller (which make/model?)
- consider buying one?
- consider making your own?
If you already own one - what are your experiences with it overall? What works, what doesn’t? Would you recommend it?
As for myself, my 2020 Africa Twin already has a built-in controller which can be used with Apps on Apple Carplay and Android Auto.
It can be also used with an Android “AI-Box” that also connects using Carplay/Android Auto interface, but can run apps that do not support CP/AA, similar to a smartphone. Some of the App can be controlled partially, even Kurviger.
I wrote a short description in a separate post here: Honda specific User Interface - #4 by t00thl355
Unfortunately, I haven’t found a way to redefine the keys effectively or connect it directly to a smartphone somehow.
Another thing I tried was building my own based on MotoButtons (GitHub - joncox123/MotoButtons: Low cost, waterproof controller for motorcycle navigation, phone and media control), but due to my lack of knowledge in
Arduino, I did not yet succeed to make a working prototype.
I did however manage to make a working Prototype of BarButtons (BarButtons: Control motorcycle navigation from the handlebars) - it is quite easy if you are able to follow the instructions for flashing the Arduino board and soldering a bunch of wires to the switches.
I also tried experimenting with several cheap controllers intended for audio controls, and could use them for zooming the map, but not much more then that.
Deutsche Übersetzung aufklappen...
Ein paar Fragen an diejenigen, die an dieser Funktion interessiert sind:
- besitzst du bereits einen Controller (welche Marke/Modell?)
- würdest du einen kaufen?
- würdest du einen selbst bauen?
Wenn bereits einen Controller besitzst - wie sind deine Erfahrungen damit? Was funktioniert, was nicht? Würdest du dn empfehlen?
Was mich betrifft, meine 2020 Africa Twin hat bereits einen eingebauten Controller, der mit Apps auf Apple Carplay und Android Auto verwendet werden kann.
Der kann auch mit einer Android „AI-Box“ genutzt werden, die sich ebenfalls über Carplay/Android Auto verbindet, aber ähnlich wie ein Smartphone auch Apps ausführen kann, die CP/AA nicht unterstützen. Einige der Apps können teilweise gesteuert werden, auch Kurviger.
Eine kurze Beschreibung habe ich hier in einem separaten Post geschrieben: Honda specific User Interface - #4 by t00thl355
Leider habe ich keine Möglichkeit gefunden, die Tasten effektiv umzudefinieren oder irgendwie direkt mit einem Smartphone zu verbinden.
Eine andere Sache, die ich versucht habe, war MotoButtons zu bauen (GitHub - joncox123/MotoButtons: Low cost, waterproof controller for motorcycle navigation, phone and media control), aber mangels Erfahrung mit Arduino ist es mir noch nicht gelungen, einen funktionierenden Prototyp zu bauen.
Ich habe es jedoch geschafft, einen funktionierenden Prototyp von BarButtons (BarButtons: Control motorcycle navigation from the handlebars) zu bauen - es ist ziemlich einfach, wenn man in der Lage ist, die Anweisungen zum Flashen des Arduino-Boards zu befolgen und ein paar Tasten mit Drähten zusammen zu löten.
Ich habe auch mit einigen billigen Controllern experimentiert, die für Audiosteuerungen gedacht sind, und konnte sie zum Zoomen der Karte verwenden, aber nicht viel mehr als das.
